Author Topic: EEVblog #495 - Kodak DCS315 DSLR Teardown  (Read 13331 times)
Online EEVblogTopic starter
« Last Edit: July 17, 2013, 01:58:28 am by EEVblog »
Offline richcj10
Re: EEVblog #495 - Kodak DCS315 DSLR Teardown
« Reply #1 on: July 17, 2013, 01:15:11 am »
battery batup... lol  ::)
« Reply #2 on: July 17, 2013, 01:30:54 am »
Did I say that?  :-[
Offline MrAureliusR
« Reply #3 on: July 17, 2013, 02:40:36 am »
It seems you have a pretty difficult time reading the chip numbers through the camcorder LCD eh? Don't blame you -- I know how difficult it is! I'm amazed you can solder while looking at the LCD. You've got almost no depth perception when you do something like that through a camera!
Thanks for another cool video :)
Canadian hacker
« Reply #4 on: July 17, 2013, 02:43:44 am »
Yes, it's not easy even though it's a 900K+ pixel 3" LCD. I sometimes have to look over the top of the camera while talking.
I miss a lot of stuff that is obvious to people watching the video in HD.
Offline The_Penguin
« Reply #5 on: July 17, 2013, 02:46:39 am »
Those screwed-down flat-flex connections are the most bizarre thing I've seen in a while.
Can you imagine sitting down and figuring out that you needed to do that?   :o
Offline richcj10
« Reply #6 on: July 17, 2013, 02:50:47 am »
Did I say that?  :-[
you fixed yourself...its just funny.....
« Reply #7 on: July 17, 2013, 02:59:26 am »
Yes. At what point in the design process do you go from thinking that a few complete right angle flex cables would do the job, to some convoluted multi level contact scheme with clamps?  :-//
Offline MrAureliusR
« Reply #8 on: July 17, 2013, 03:05:56 am »
The point in the design where the engineers are sick of being micro managed so they throw a curveball back at management ;)
Canadian hacker
Offline Rasz
    • My random blog.
« Reply #9 on: July 17, 2013, 03:30:29 am »
maybe hang 32' TV on the wall in front of you and connect it to the camera, would that make your life easier?
« Reply #10 on: July 17, 2013, 03:31:45 am »
Yes, that must be it!
Offline steve30
    • Stephen Coates' Homepage
« Reply #11 on: July 17, 2013, 05:43:07 am »
Any plans to try and get the camera to work or find out what's wrong with it?
Offline firewalker
  • Country: gr
« Reply #12 on: July 17, 2013, 08:59:03 am »
I you remove that alen screw it will fall apart in halves?
Alexander.
Offline robbak
« Reply #13 on: July 17, 2013, 10:02:57 am »
I assumed that the contact mechanism was the connector to the back panel of the original camera. Even then they are still strange connectors. Maybe some of them are motor connectors? Rotation/position sensors?
Weird, that is for sure. The LCD window lower down is the standard LCD on the film camera. Love to see a teardown of the film camera.
Offline Hypernova
  • Country: tw
« Reply #14 on: July 17, 2013, 04:33:55 pm »
That is one insane franken camera. Wonder how many they sold?
Offline ttp
« Reply #15 on: July 18, 2013, 01:53:09 am »
Probably from original Nikon Pronea 600i, look a bit like for rotary dials/switches on the back of camera or sensors.
Offline ptricks
« Reply #16 on: July 18, 2013, 02:12:58 am »
I am curious to see what kind of lighting they use for the LCD. I have a Casio QV-770 camera, really old, 640x480 max resolution, 4MB storage, no card slots, serial port used for download via a 1/8 audio style jack.  They use a custom fluorescent tube , it is white and square the size of the LCD and about 3mm thick with a small glass pipe on the side for the electrode wires, never seen anything like it.
I plan to post photos of the tear down when I get time.
wow the casio is 15 years old, must have been one of the first.
« Last Edit: July 18, 2013, 02:15:37 am by ptricks »
« Reply #17 on: July 18, 2013, 05:31:09 pm »
For that I would guess a panaplex tube, it was a flat panel discharge lamp with a discharge confined to a channel by dimples in the glass backing, and front phosphored. Originally developed as a flat lighting panel to replace a standard cieling tile with a diffuse light source, but never was popular due to the high cost of making them. A small rectangular one though would be a good light source ( in the days before they got a good way to make a diffuser that would provide even illumination from a line source at the one edge) for such a display.
Offline Moshly
  • What's wrong with this thing
« Reply #18 on: July 19, 2013, 08:09:25 am »
Hey Dave
That PCMCIA socket is easy to remove, no soldering required.
It's a socket in a socket, very common on notebook computers.
Just remove the 4 screws & splay the black clips  ;)
Offline Garywoo
« Reply #19 on: October 16, 2013, 06:13:09 am »
Alexander.
I was dying for him to unscrew that, it appears to be the original host camera tripod mount screw.
