Author Topic: EEVBlog #439 - Atten PPS3205T-3S Triple Output Power Supply Review  (Read 38422 times)
Offline BravoVTopic starter
  • +++ ATH1
If Atten released the mcu programming to public, or "leaked"  >:D for a complete tweaking or even better re-doing the UI, I'm guessing this thing will sell like a hot cakes since the underlying power/analog part is quite good isn't it ?
Love it Dave, the detail performance review and the torturing too !  :-+
« Last Edit: March 18, 2013, 08:09:03 am by BravoV »
Offline konfu
Re: EEVBlog #439 - Atten PPS3205T-3S Triple Output Power Supply Review
« Reply #1 on: March 18, 2013, 07:51:34 am »
What about your rule "Don't turn it on - take it apart!"?? I'd love to see the PCB, Transformer, input protection and so on. ;-)
But seems like a nice little chunk of equipment.
« Last Edit: March 18, 2013, 07:54:46 am by konfu »
  • +++ ATH1
« Reply #2 on: March 18, 2013, 07:56:03 am »
What about your rule "Don't turn it on - take it apart!"?? I'd love to see the PCB, Transformer, Input protection and so on.
Its way too long for single episode, imo that review it self shows in details how to test & torture a psu, love it.  :-+
Maybe at next episode.
Offline peter.mitchell
« Reply #3 on: March 18, 2013, 08:16:30 am »
not at all! I was expecting it!
Online EEVblog
« Reply #4 on: March 18, 2013, 08:18:34 am »
I actually shot the teardown after the review and before I shot the final conclusion. So my rating is also takes into account the internal construction (some poor soldering, but otherwise ok), but I forgot to mention that :->
Teardown is already uploaded, coming tomorrow. 45min worth!
Dave.
Online EEVblog
« Reply #5 on: March 18, 2013, 08:20:38 am »
I thought this episode was also way too long, and there is already some stuff left out. I didn't want to spend the time to edit and refine further.
The teardown is an additional 45min, and includes some extra testing. I had to re-shoot almost the entire thing, wait for the rant in the video...
Dave.
Offline Rerouter
« Reply #6 on: March 18, 2013, 08:56:00 am »
so to kill the gap, was it high side or low side current measurement, or some combination?
  • +++ ATH1
« Reply #7 on: March 18, 2013, 09:40:24 am »
Dave.
Even its 1 or 1.5 hours is still fine, IMO.
Also merging it with a tear down part might "dilute" the quality weights of this kind of highly technical review video, again, maybe its just me.  :)
« Last Edit: March 18, 2013, 09:42:34 am by BravoV »
Online Psi
« Reply #8 on: March 18, 2013, 09:48:15 am »
I wonder what it would do if ch 1 was shorted to ch 2 in reverse polarity.
Then let the current limit on each channel fight it out.  %-B
« Last Edit: March 18, 2013, 09:50:01 am by Psi »
Offline Ketturi
    • Ketturi Electronics
« Reply #9 on: March 18, 2013, 10:11:54 am »
If it has some generic MCU, the firmware could be hackable. If someone have too much time on their hands, it could be possible to reverse engineer the original FW, and fix those annoying bugs and issues, or completely rewrite FW and include more options and better user interface. Too often the case is that UI sucks in cheap equipment, even tough usually it is most important part. Does designing cost that much? Is it reason why professional devices have so high price? Maybe in future we have same hardware in both price ranges, but supplied software is different. And at same time we have superb open source software that costs nothing...
Ketturi electronics: http://ketturi.kapsi.fi
Online EEVblog
« Reply #10 on: March 18, 2013, 10:37:20 am »
I didn't investigate that far. To take the boards out would have required stripping the whole thing.
Dave.
Offline biot
« Reply #11 on: March 18, 2013, 11:36:45 am »
I have the 3A version of this (PPS3203T-3S). One of the major reasons I bought it was for the serial programmability, and as Dave noticed, that doesn't work at all. The download for the 3203 was a broken link, and the 3205's software just didn't work.
It looks like somebody sat down with some VB or similar GUI design tool, dropped in some windows, and shipped that. I'm not even kidding: I ran this in a VM, selected the serial-USB port and told it to connect while sniffing USB traffic going through the VM. It doesn't touch the serial port at all; not a single USB packet. FWIW I do this all the time on that VM; the method works, the software does nothing.
I sent a mail to Atten, but received no reply of course. Not that I was expecting anything there. The distributor where I got it (TME) also declined to reply. It looks to me like Atten simply did not implement the programmability feature, but is still selling it that way. Very, very questionable.
I had a look inside. The separate serial board goes to an MCU board, centered around a chip labelled STC 89C58RD+. A quick google turned up a datasheet that contains a few package outlines and no text whatsoever. Good luck getting it to work by reverse engineering that.
I didn't actually get a sheet with serial commands with the unit, only the manual. Dave, any chance you could post this? I'd really like to see if it's at least implemented in the firmware.
Offline Dr_Welt
« Reply #12 on: March 18, 2013, 12:07:13 pm »
First of all, I'm new here.
So hi Dave, hi to all.
I saw the review, and it made me smile. Actually I have the "ISO-TECH 3202". The Atten PSU seems to be very simmilar, if not in some parts the same. Have a look at the (same annoying) user interface.
Actually mine can't be programmed in the same way, and my knob cant be pushed. *BUT* I can save and recall channel configurations. :)
Here are some pictures I made the day I got it from ebay.
https://www.icloud.com/photostream/#A45oqs3qdVAvn
BTW. mine has a "secret" menu, which I found. By pressing shift-"." you can enter "calibration mode"
Thanks for the nice review,
Ole.
Offline nitro2k01
« Reply #13 on: March 18, 2013, 01:57:06 pm »
It's a good thing you 'straighans live in the future, so Tuesday typically means "late Monday" to the rest of the world.
Offline firewalker
  • Country: gr
« Reply #14 on: March 18, 2013, 02:15:49 pm »
Nice review.
I actually believe it's normal not to be able to change channels synchronously when in series mode. If so it wouldn't be possible to produce asymmetrical voltages (e.g. +5. -10), or odd voltages (e.g. 45 volts) since only ch2 is settable. Set channel one, select series mode, set ch2 turn outputs on.
Alexander.
Offline Bored@Work
« Reply #15 on: March 18, 2013, 02:58:27 pm »
What did Dave say in the intro "a pretty high-end bit of kit"? That train wreck passes as high-end? Muhahahahaha  :-DD  :-DD  :-DD
Offline firewalker
  • Country: gr
« Reply #16 on: March 18, 2013, 04:16:41 pm »
Dave, did you had a peek inside before the review?
Alexander.
Offline c4757p
  • adieu
« Reply #17 on: March 18, 2013, 05:36:46 pm »
Am I the only one who's really, really horrified by the display? As in, "no way in hell would I ever buy it" horrified? The almost-white-on-slightly-less-white is ghastly. I think I would spend as much time squinting at it as I do operating it!
Offline Rufus
« Reply #18 on: March 18, 2013, 05:47:37 pm »
I think you would need to see it in the 'flesh' to judge. I have a cheap Chinese electronic load with white on blue LCD and its fine. I only skipped through the video and didn't notice if Dave tried adjusting the contrast.
Offline AndyC_772
« Reply #19 on: March 18, 2013, 07:03:11 pm »
Nope. There's really no excuse for such a cheap, nasty display, especially in a piece of otherwise (apparently) well constructed equipment.
It doesn't seem inappropriate given the quality of every other aspect of the UI, though.
I can think of quite a good project for anyone with some spare time on their hands, though. The hardware in the box seems OK, and the whole thing is serial programmable, so I wonder whether it might be possible to build a dedicated external controller for this thing with a better LCD and front panel controls? It could be quite a good "my first PIC" project; rather than building a power supply from scratch, just make a relatively inexpensive off-the-shelf one usable.
Of course, the first problem is how to power the PIC...
Offline jancumps
  • New Low
« Reply #20 on: March 18, 2013, 07:16:27 pm »
... wait for the rant in the video...
Yeah!
Offline johnnyfp
« Reply #21 on: March 18, 2013, 07:56:42 pm »
Dave,
Where did you buy it from?
Offline Pilot3514
« Reply #22 on: March 18, 2013, 08:06:33 pm »
Dave,
Did this give you any ideas for features to add to you Micro Power / USB Power supplies?
Given that you have a processor/controller with a UART already, seems like serial control is a good feature.
The UI may not be everything but as you have shown, it can take a really nice bit of kit and turn it to piece of ****.
I'm not cheap, I'm frugal
unlike those wasteful Scotch.
Offline lewis
  • Nullius in verba
« Reply #23 on: March 18, 2013, 08:07:38 pm »
 :-DD
I will not be pushed, filed, stamped, indexed, briefed, debriefed or numbered.
Offline nixxon
  • Country: no
« Reply #24 on: March 18, 2013, 08:14:57 pm »
Hey, at least the USB connector is connected to the inside circuitry. Unlike Atten's AWG's...
