Author Topic: EEVblog #1210 - Sony Waterproof Earphones Teardown  (Read 2612 times)
Offline EEVblogTopic starter
« on: May 09, 2019, 11:00:59 pm »
How do you make waterproof earphones?
A teardown of the Sony Walkman NWZ-WS613
Also talk on o-rings and waterproofing electronics.
Offline DDunfield
Re: EEVblog #1210 - Sony Waterproof Earphones Teardown
« Reply #1 on: May 10, 2019, 01:15:05 am »
You mentioned that the white inner caps were quite difficult to pry out. Could the green ring be some sort of waterproof sealant/glue applied when the cap is fitted, and perhaps it dried out over time becoming completely hard, which might explain the eventual waterproofing failure?
Dave
Offline msg90
« Reply #2 on: May 10, 2019, 09:57:42 am »
Hello everyone!
As the guy who sent it in, where I was initially suspecting the water to get into the device was through the place where the behind-your-neck cord meets the casing. I will be honest, I never figured the best way to take them off from my head and I sometimes got a weird angle on that cord, when I tried either to take off the swimming cap or to take the cord out from under the cap. Now I bought a newer model and it appears that Sony also acknowledged this area as the 'danger zone' and added a large rubber pieces:
EDIT, there is a microphone visible in the casing at 5:05 on the left (bottom part, near the buttons), for making calls via Bluetooth.
Also, 'shoutout' to the Sony Poland Service Centre, that claimed that there's nothing wrong with this device, 'It's just completely discharged'. Oh well ;).
Cheers!
« Last Edit: May 10, 2019, 10:13:25 am by msg90 »
