Author Topic: EEVblog #1059 - Quick 861DW Hot Air Waveform Measurement  (Read 4152 times)
Online EEVblogTopic starter
« on: February 21, 2018, 01:06:23 am »
An update on the Quick 861DW, and probing its current consumption in comparison to the Atten 858D+ with the TTi I-Prober
https://kit.com/EEVblog/test-gear
Offline LA7SJA
  • Country: no
  • Acting user manual reader & forum search engine
Re: EEVblog #1059 - Quick 861DW Hot Air Waveform Measurement
« Reply #1 on: February 25, 2018, 09:30:13 am »
Hei Dave, you forgot that Louis Rossmann's lab has 110V@60Hz so 1000W is 9.1A and I  think the cabling vill generate som voltage drop if the station is on the same phase as the lightning. This blinking is not unusual with LED lightning and large current pulses on the supply lines.
Johan-Fredrik
"If at first you don't succeed, skydiving is probably not for you"
