Loading [MathJax]/extensions/Safe.js
Author Topic: Constant current source with supply voltage swing  (Read 5020 times)
Offline haeciferTopic starter
  • Country: br
« on: November 02, 2015, 08:45:31 pm »
Hello everyone,
I am looking for a simple current source that is able to provide a constant(ish) current even with a small supply voltage swing.
My ultimate goal is to use this current source to provide a stable reference current to a current mirror I have.
As an example of the problem that I am facing, please consider the image attached. The current mirror is being polarized by the resistor R4. However, any variation on -Vcc will change the reference current considerably and that is an unwanted effect to me. Thus, I need a current source with a certain resistance to supply voltage variation to polarize transistor Q6.
One limitation that I have is that I can only work with transistors, resistors or capacitors; so no zener diodes allowed.
Is anyone aware of a solution to this problem?
Thank you all in advance!
Online Ian.M
Re: Constant current source with supply voltage swing
« Reply #1 on: November 02, 2015, 09:00:31 pm »
Disconnect the top end of R4 from Gnd and stabilise it with a 'Vbe multiplier' between there and the negative supply, with a pullup to Gnd or the positive supply depending on the headroom required.
Offline Jay_Diddy_B
« Reply #2 on: November 02, 2015, 09:08:19 pm »
Welcome to the Forum !!
Here is another idea that might work for you. It depends on how accurate you need the current source and over what temperature range.
I have added R1 and D1 to stabilize the voltage across R4 and therefore the current.
D1 was chosen at 6.2V to be relatively stable with temperature.
Regards,
Jay_Diddy_B
Online Ian.M
« Reply #3 on: November 02, 2015, 09:14:36 pm »
@Jay: O.P. said "One limitation that I have is that I can only work with transistors, resistors or capacitors; so no zener diodes allowed. "
Offline Zero999
  • 0999
« Reply #4 on: November 02, 2015, 09:19:50 pm »
To be picky what you've posted is a current sink, not a source. Reverse the polarity, diodes and change the transistors to PNP and you have a current source.
Here are two ways to make a constant current sink which doesn't vary much, as the power supply voltage changes.
  • Country: br
« Reply #5 on: November 02, 2015, 09:28:34 pm »
Thank you all for the input, it was very helpful to me.
The Vbe multiplier that was suggested by @Ian.M (and was also on the image @Hero999 posted) will do the trick for me so thanks once again.
Offline Zero999
  • 0999
« Reply #6 on: November 02, 2015, 09:40:24 pm »
No a VBE multiplier is something completely different.
Online Ian.M
« Reply #7 on: November 02, 2015, 10:02:27 pm »
+1
Its basically a 'roll your own' Zener substitute but with much worse slope resistance and temperature stability
