Author Topic: Salvaging cores for gate drive transformers  (Read 4103 times)
Offline MrOmnosTopic starter
  • Country: np
  • BE in Electronics and Communication
« on: January 20, 2017, 05:01:20 pm »
Hi folks!
What devices have good a core for a gate drive transformer? I need some cores and I can't buy them here. I have used some computer psu cores but they are horrible. So, I think I might have to do some junkyard diving. Anyone has any idea what devices have good cores for a GDT which reproduces good wave form. I have heard audio amps have good cores in them but I want some other devices so when I go to the junk yard I won't have to return empty handed.
Thank!!
Offline KhronX
    • Khron's Cave - Electronics Blog
Re: Salvaging cores for gate drive transformers
« Reply #1 on: January 20, 2017, 06:56:33 pm »
Slightly older / crappier ATX computer power supplies, half-bridge designs (often with beefy BJT's) based on TL494 / KA7500 / SG6105 usually have the PWM controller on the secondary side, and a GDT driving the switching components. If needed, it shouldn't be too big of a deal to re-wind them, i'd think.
Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
« Reply #2 on: January 20, 2017, 07:19:01 pm »
Hi folks!
Thank!!
Don't you mean Pulse transformer ?
Have a look on eBay, there's lots of small ferrite pot core types available.
Just be sure to select one that is suitable for gate drive duties and with an adequate isolation rating and the turns ratio you need.
  • Country: np
« Reply #3 on: January 20, 2017, 07:24:00 pm »
Hi folks!
Thank!!
Nope can't do that. No buying from ebay, amazon, alibaba. 3rd world problems.  :P
  • Country: np
« Reply #4 on: January 20, 2017, 07:26:48 pm »
Rewinding is not a problem tho, problem is most cores I have tested have produced unusable waveform. I think I have one as you described.  :D It that giant coil you talking about?
I pulled out a smaller one and it  is cheap stuff. But that giant one looks more like a GDT. It has multiple winding. Is that what you are talking about.
Offline bktemp
« Reply #5 on: January 20, 2017, 07:35:17 pm »
T2 was the transformer used for driving the transistors.
The large toroidal core is a iron powder core, useless as a gate drive transformer.
The following users thanked this post: KhronX
  • Country: np
« Reply #6 on: January 20, 2017, 07:47:14 pm »
Found it!
This is T2. Will this work? How do I use this this? Where can I find about it internals?
Offline bktemp
« Reply #7 on: January 20, 2017, 07:56:43 pm »
http://danyk.cz/s_atx_en.html
It is designed for driving BJTs, so for mosfets you probably need to rewind the transformer using more turns for the output windings.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #8 on: January 20, 2017, 09:08:18 pm »
That should work. The line filter would also be good.
Line filters, common mode chokes, etc. have pulse-transformer type cores in them.
You should learn how to use transformers -- the math is simple, and you will no longer wonder why some cores work and others don't.
Tim
Seven Transistor Labs, LLC
Offline Red Squirrel
« Reply #9 on: January 20, 2017, 10:59:14 pm »
I'm new to the world of transformers myself so I could be way off here, but could one use a couple stacked washers to build a simple low power transformer?  You'd probably want to isolate them with something to prevent edy currents.
Offline T3sl4co1l
« Reply #10 on: January 21, 2017, 12:23:02 am »
Not with most grades of steel, not very practical.  Quite high losses.  It would work well enough to demonstrate, but that's about it.
The shape is correct for a toroid, though -- they can be made from stacked discs or wound strip.  Most are stripwound, because it's easy, of course. :)
Tim
« Reply #11 on: January 21, 2017, 03:45:17 am »
Useful site for more understanding of transformer construction:
http://ludens.cl/Electron/trafos/trafos.html
