You can't coat it in something conductive, cause that would short out the connections
. Do as CM800 says and pot it. If you want an easy and cheap prototype you can even try to pot it in hot glue, of course that wont be a good long term solution.
But you know it's a thesis, so it only has to work ONCE, and that is during the thesis presentation
