Well, here in South Africa pretty much every garage has a generator ( thank you Eishkom) along with a lot of homes. Problem with a garage is the tankage is mostly enough to run for around 3 days before they need a refill from a tanker truck, so after 3 days most if not all garages will be out of either all fuel or the most popular in that area.
As for the pylons failing in a line, it is most likely a wind loading, with the wind being strong enough that the force caused one bolt to fail, probably from being loose for a while ( vibration in those towers does mean they tend to have issues with fasteners coming loose, especially if they are not regularly inspected to to bottom by a crew that does a check on each single connection, which I would bet has not been done here properly for a decade or more) and which fell out, leading to the redundant bolt taking the full load. Then this weak bolt ( on the lee side, so with a compressive load in addition to the static load from the pylon and the cables) failed in the storm, and the tower started to sway, and this oscillation built up till the support members buckled and it went down. This then added a massive step loading to the pylons both sides, and the insulators did not fail there, but dragged the structure with a massive side load, causing a similar buckling that propagated down till there was either a bend in the line to provide relief, or the line went over a hill doing the same, or the cables snapped or the insulators failed and dropped the lines. In any case there would have been a ground faule as the first pylon collapsed, which would have tripped the line, and then 2 further reclose events before the supply side feed flagged the line as a hard failure and locked it out.
