Author Topic: New Rigol DS1054Z oscilloscope  (Read 2057192 times)
Online Fungus
« Reply #3400 on: March 24, 2017, 09:17:32 am »
btw. what principles does the scope follow when AUTO setting memory depth ?
Is it worth, on average, leaving it on a manual setting?
I vote 'no'.
You'd have to set it almost every time you use the horizontal knob.
The following users thanked this post: k8943
Offline JPortici
« Reply #3401 on: March 24, 2017, 11:00:09 am »
i'd say no.
the scope will always try to maximize wfm/s.. leaving in "auto" means better chance to catch the event. once you have found a way to trigger on it, set the timebase/amount of memory accordingly so you can trigger on the glitch AND have a good look at before/after
Offline k8943
« Reply #3402 on: March 24, 2017, 07:49:52 pm »
Brightness effect noted (!!) the pulse width distortion is nuts. Would never have figured that one out. Thanks.
OK I see there's a clear consensus to play with mem depth after everything else is right. One of the reasons I asked was that so far the scope seems to systematically use a mem depth setting that is VERY low compared to its capacity. Even accounting for numbers of channels and so forth. That seemed strange.
Will experiment more.
Offline metrologist
« Reply #3403 on: March 24, 2017, 10:37:00 pm »
I noticed the low memory depth too and figured they were making a trade-off with some other performance attribute. wfs seems likely.
Offline tcurdt
« Reply #3404 on: March 25, 2017, 12:06:13 am »
Just received my DS1054Z. So far I am somewhat happy with it - but some of the UI I just don't get.
Right now I am struggling with the Auto Measurement Items.
I press a button and the item appears - but how do I make it disappear again?
The manual only talks about "activating" them.
When I press it again it says "Existed item!"
Let's forget about that grammar - but I must be missing something.
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #3405 on: March 25, 2017, 12:12:56 am »
Page 6-26 of the user's guide -
https://www.sicamax.ch/downloads/mso1000zds1000z_userguide_en.pdf
Offline hexreader
« Reply #3406 on: March 25, 2017, 12:15:31 am »
May be wrong - but something like...
   Measure
     sel item
         (untick unwanted items)
Good luck with this annoying interface.  Rigol are forgiven for this crime, as the scope is cheap and has a lot of cool features/buttons :)
Offline tcurdt
« Reply #3407 on: March 25, 2017, 12:24:33 am »
Thanks for the response but - not really. I tried that too.
I select "delete all" and they all disappear. (Yay!)
Then I select a single one and the rest of them appear again.
(Being someone who has worked in the UX area I want to slap whoever came up with that UI.)
Online RoGeorge
« Reply #3408 on: March 25, 2017, 12:37:31 am »
Indeed, it's annoying. This is how it always was.
The only workaround I know (in order to make the unwanted measurements to go away) is to cycle the power of the scope, but this is totally unpractical.
Offline tcurdt
« Reply #3409 on: March 25, 2017, 12:38:19 am »
I just wanted save a screenshot to demonstrate - but seems like it does not like any of my USB sticks.
It just keeps saying "No USB disk!" >:(
Offline tcurdt
« Reply #3410 on: March 25, 2017, 12:41:24 am »
Urgh. At least it's not me then.  :wtf:
Thanks!
Offline tcurdt
« Reply #3411 on: March 25, 2017, 12:50:08 am »
Works now - after a restart.  ???
Offline bitseeker
« Reply #3412 on: March 25, 2017, 01:38:06 am »
The manual only talks about activating them because there is no way to make individual measurements disappear. You can hide them all or replace them with the ones you want.
Yeah, you can take a swing once I'm done with them. It's one of the worst examples of interaction design I've seen in a long time. :palm:
Offline alsetalokin4017
« Reply #3413 on: March 25, 2017, 02:23:59 am »
Wrong.
« Reply #3414 on: March 25, 2017, 02:26:35 am »
Oh, I've seen worse. It's not so bad once you get used to it. "Pluses" and all.
Offline bitseeker
« Reply #3415 on: March 25, 2017, 03:24:38 am »
Wrong.
Holy smokes! They sort of fixed it. You used to only be able to gray an item out, not delete it.
Unfortunately, it's still screwy as soon as you add a new one.
« Last Edit: March 25, 2017, 03:34:36 am by bitseeker »
Online RoGeorge
« Reply #3416 on: March 25, 2017, 03:25:44 am »
Wrong.
Meh, not exactly.
First, it's cumbersome, and it is useful only to prepare a nice screen for a capture.
Second, as soon as a new measurement is added, the old (unselected or deleted) ones appear back, but as greyed out.
Offline bitseeker
« Reply #3417 on: March 25, 2017, 03:32:06 am »
I remember that behavior, but when I try it on the latest firmware, the old deleted ones not only come back, but they're not grayed out. It's even weirder than before.
Offline _Wim_
« Reply #3418 on: March 25, 2017, 06:40:47 am »
Wrong.
Meh, not exactly.
What is also annoying, is when you change the font type of the measurements, only 3 measurements can be shown (that is normal because or limited space), but the scope still remembers 5!
This means when you want to add a measurement that is already displayed as invisible measure "4" or "5", the scope says "measurement already added". The only way to display that measure, is first to add 2 more other measurements that you do not need, and then select the one you need again...
Offline JPortici
« Reply #3419 on: March 25, 2017, 06:49:15 am »
indeed. you are starting to see how deep memory is more of an obstacle most of the time because you need much much much more processing power and of course increased blind time to process all that additional data. the trick is low amount to get the triggering right and only then a single shot at full memory depth
also be careful that the scope will go crazy (recognize, no recogniza, save, not save, save only some data, ...) with memories greater than 2 (or 4) GB. it's written only in the troubleshooting guide. no mention in datasheet/related user guide section
Offline _Wim_
« Reply #3420 on: March 25, 2017, 06:55:14 am »
It really depends on the type/brand of USB stick. I experimented with all of them I had around, and a few of them work without any problems (older types with "only" 1 GB of memory). But these work always flawlessly, so I keep them for use the them scope only.
« Reply #3421 on: March 25, 2017, 07:27:26 am »
Some of these responses puzzle me. I have no trouble displaying just the measurements I want to show, turning others off, adding new ones or displaying old, previously turned off measurements. Of course I actually use the scope every day to make measurements (however quirky or wrong or misspelled they may turn out to be) so I am very familiar with how the system operates. It appears that some people weren't even aware of the "Select Item" list or haven't used it very much. I suggest playing around with this feature a bit; eventually it will "sink in" and you'll be able to use it to display what you want, without being troubled by the "greyed out, inactive but displayed anyway" problem. Use the "Select Item" list to remove undesired greyed-out items from the screen display.
Perhaps it may help to think of the measurement display as a sort of list buffer that holds the last five that you have selected and allows you to turn on or off any of those using the "Select Item" list. When you want to add a sixth one, it goes in the fifth place and pushes the rest down one position, and the old "first" one is gone. It gets slightly more complicated when you have Large or ExtraLarge fonts selected since only three or two of the five can be displayed at one time, or if you insist on displaying your chosen measurements in some particular order.
No, that's not right either, if I am understanding you correctly. You just need to use the "Select Item" list to turn off one of the measurements of the three that are displayed, then you can turn on the one you need again.
Sure, the Rigol software often appears to be a set of "kludges" that were cobbled together by a committee of junior programmers who have never actually used an oscilloscope... but who remember playing with those complicated Chinese puzzle boxes as kids.
But what did you expect, it's only 400 dollars.   :horse:     Shouldn't you be happy that it even "pretends" to do measurements at all?   :palm:
Offline John at the Falls
« Reply #3422 on: March 25, 2017, 09:11:13 am »
Unlocking features.
March 25 2017
I just got my brand new DSO1054 today.
Just want to report my experience.
Firmware is 00.04.04.01  (00.04.04 SP 1)
This is the version that was pulled down for upgrading an existing scope but I guess it is OK since this came from the factory with this version.
The upgrade went smoothly even with bleary eyes from staying up late playing with this thing.
People may want to read the release notes to see if a firmware upgrade is really necessary from the version they have.
I followed these instructions
Can not believe it only cost $400 USD. I will be using it to work on CNC systems and Arduinos.
I ordered 12 18650 batteries to make a DC power pack so I can have a Mains isolated system. I will post when that happens. It is only a bit bigger than some of the handheld units and much more capable at a lower price. Isolation is the only compromise I made when selecting this scope.
« Last Edit: March 25, 2017, 11:24:28 pm by John at the Falls »
Slave to my Thermodynamics Muse.
Test gear: Weather Rock, Bigger rock for taking things apart
Stick for poking things, Rooms full of books, Curiosity.
Online madires
« Reply #3423 on: March 25, 2017, 10:27:18 am »
Any news about the new firmware version? Someone mentioned January or February.
« Reply #3424 on: March 25, 2017, 11:59:09 am »
I strongly recommend a burn-in period before making any changes to a newly-purchased scope. There is always a chance that you may have gotten a defective product that will at some point refuse to boot and refuse to allow you to remove the "hack", which may cause difficulty if you need to return it for a warranty replacement. You have a trial period of 30+ hours of use for all options except the 100MHz bandwidth increase. So use that time to confirm that you have good hardware and won't be needing to return the unit for vendor's or factory warranty service.
